Normal Topic Scale timeline in resourceview (Read 1702 times)
urunkel
Sep 4th, 2007 at 5:50am
I am using the planner in resourceview. In the form I placed buttons to change the timelinescale to zoom in and out. This all works fine. Finally I wanted to implement a function that shows a whole month. So I have to resize the timelinescale to see from 28 up to 31 columns, depending on the selected month.
Can I find out either the width of a single column or the last visible day with the actual selected timelinescale or is there any other solution I didn't get yet?
Thanks in advance.
Re: Scale timeline in resourceview
Reply #1 - Sep 4th, 2007 at 9:20am
You can obtain the currently visible start and end dates through the GetFirstVisibleDate and GetLastVisibleDate methods of the Calendar class. These methods take into consideration the current timeline scale.
