Normal Topic active object changed (Read 1248 times)
shil
Sep 12th, 2007 at 11:39am
hi. if i select with control + click some boxes the active object will change. can i avoid the changing of the active object?
thx shil.
Re: active object changed
Reply #1 - Sep 12th, 2007 at 12:19pm
Try handling the SelectionChanged event and set ActiveItem back to the original box.
