Normal Topic Repaint in DiagramNodeModifying (Read 1778 times)
sledenev
May 4th, 2011 at 2:45pm
Hello.
I'm trying to implement next behaviour: when diagram node is moving i need to detect intersection with other nodes and highlight "bottom" nodes which has been intersected.
I'm trying to solve this by adding some kind of flag in node and set it in DiagramNodeModifying event after detecting intersection. But to take new state into account I must repaint the node on every tick of DiagramNodeModifying event. This repaint is source of  significant flickering of bottom nodes.
Is there's a way to avoid frequent repaint or other way to implement my task. I can send you my sample code if required.
Thanks in advance.
Re: Repaint in DiagramNodeModifying
Reply #1 - May 4th, 2011 at 4:35pm
Are you calling DiagramView.RecreateCacheImage from the event handler? You can do that only when the flag value actually changes for some node to improve refresh speed.
sledenev
Reply #2 - May 4th, 2011 at 4:40pm
RecreateCacheImage really helps. Thank you very much!
