Normal Topic Refresh of the flowchart (Read 1096 times)
shil
Sep 22nd, 2007 at 5:57am
Hi there. I move some nodes in my chart, but if i do that via code the arrows that are connected to the node will not move too or will anchored at the wrong point of the box. i allready tried the refresh method, but it doesnt work good. is there any other wy to "refresh" or redraw all items of the chart?
Re: Refresh of the flowchart
Reply #1 - Sep 22nd, 2007 at 11:18am
If your problem is that after moving a node the links lose their initial shape or don't follow a nice path between the nodes, try this:
- enable the link.RetainForm property before setting the new node.Bounds; this will preserve the initial arrow shape;
- or call link.Route() after moving a node, and the control will assign a new path to the link so that it does not cross any nodes;
In both cases, set link.Dynamic = false before moving a node if you wish to preserve the link's original anchor points.
