Normal Topic New v1.0.1 client events ? (Read 4770 times)
oakenshield
Oct 5th, 2007 at 12:15pm
I've just read that v1.0.1 had been released, it's great, but I wonder how do the new validation events work, particularly the ArrowDeleting, BoxDeleting and TableDeleting events.
Can anyone answer to this question ? I think it would be useful for the most of us. Smiley
Thanks !
Re: New v1.0.1 client events ?
Reply #1 - Oct 5th, 2007 at 12:23pm
You just return true from the JavaScript function to allow the operation, or false to prevent it.
E.g.
funciton onDeletingArrow(arrow)
	if (confirm("Are you sure?"))
		return true;
	return false;
And of course you must assign "onDeletingArrow" to the ArrowDeletingScript property.
oakenshield
Reply #2 - Oct 5th, 2007 at 12:26pm
That's it, thanks a lot !
[EDIT]
By the way, I suggest to use this one-line function, it's the clearest and simplest code :
function onArrowDeleting( arrow )
    return confirm( 'Are you really sure ?' );
Reply #3 - Oct 5th, 2007 at 12:51pm
You are a true Javascript Guru 8)
oakenshield
Reply #4 - Oct 8th, 2007 at 10:48am
I have a new question about these new events : onDeleting-functions works well, but I didn't succeed to use functions like onBoxMouseEnter... Any idea ? What are the arguments of such a function ?
Thanks in advance.
Reply #5 - Oct 8th, 2007 at 11:29am
The function definition should look like
function onBoxMouseEnter(box, mouseX, mouseY)
You can find them all in the help file: expand the "Client side reference" branch in the contents tree and open the first topic, "Client side events".
oakenshield
Reply #6 - Oct 9th, 2007 at 6:59am
Ok, I found my problem : in fact, I launch the applet directly in Javascript by using MindFusion.setInnerHtml function, and I tried to assign the "BoxMouseEnter" param whereas its real name is "MouseEnterBox" !
By the way, I'm afraid I can't find the topic called "Client side events", could you give me the url ? ???
Thanks for your replies.
Reply #7 - Oct 9th, 2007 at 9:13am
Open the "Contents" tab in the NetDiagram help file, and there expand the third book-like icon, titled "Client Side Reference". The very first topic in that branch is "Client side events".
