Normal Topic Background Image (Read 3023 times)
jsamba
Background Image
Oct 10th, 2007 at 4:45pm
Hello!
I would like to insert a background image that would be printed stretched on all pages that are needed to print the diagram.
For example:
let's say my diagram holds on a single paper page.
When I insert a background image, I can't have the image stretching (or fitted) all over the page. It will be limited to the diagram itself.
Do you know a simple solution?
I think a solution is related to the definition of diagram limits....
Is it possible to easily set up the diagram limits/border to the next set of pages that can encompass it? ???
Thank you...
Re: Background Image
Reply #1 - Oct 10th, 2007 at 5:15pm
Enable the picDocument bit in the PicturePos property and the Picture will be aligned to the diagram bounds. Otherwise, if that bit is not set, you will get the image printed on every page.
jsamba
Reply #2 - Oct 11th, 2007 at 6:25pm
OK, but what if I'd like to span ONE single image over all the pages, and I would like it to stretch to the borders of the "border pages"
(the image shall not stop in the middle of a page, even if the diagram itself does not go beyond)
Is it possible?
Reply #3 - Oct 12th, 2007 at 4:48am
It's possible only if you make the document exactly as big as the total area of the pages that will fit the diagram. E.g. if you print in A4, make the document size multiple of 210 mm by 297 mm.
