Normal Topic Anchor-Points for Table-Cells (Read 1676 times)
Wolfgang
Oct 15th, 2007 at 9:37pm
is it possible to set anchorpoints in a table-cell ?
I need this, because the links are always connected at the same side of a tablerow. For a grouped object of shapes and 2 tables i need a connectionside from the left for the first table and from the right for the other table.
If i cannot get the tables work this way, i have to compose my own tables from shapenodes. Sad
Greetings,
Wolfgang
Wolfgang
Re: Anchor-Points for Table-Cells
Reply #1 - Oct 15th, 2007 at 10:10pm
just found, that rows can have anchorpoints. That works well.
Thank you for that great software. I will buy a license when my testings are finished.
Greetings,
Wolfgang
Reply #2 - Oct 16th, 2007 at 4:53am
In addition, the AnchorPoint objects have a Column
property which has effect when an AnchorPattern is assigned to a table row. That lets you define the anchor point positions relatively to the table cells.
Wolfgang
Reply #3 - Oct 16th, 2007 at 8:51pm
Hi Stoyan,
thanks for that tip. Now i can try to use 1 table instead of 2. This tool is realy awsome. Very cool object-model and easy to use.
Thanks again,
Wolfgang
