Normal Topic Print - ControlNode (Read 3731 times)
Tx2000
Print - ControlNode
Oct 18th, 2007 at 8:28am
Is it possible to print the user controls introduced in a ControlNode?
Thank you.
Re: Print - ControlNode
Reply #1 - Oct 18th, 2007 at 8:47am
FlowChart.NET automatically prints controls that paint themselves by implementing the Control.OnPaint method. If a control is a wrapper around a native Win32 control, it cannot be printed automatically.
To work around that, you can handle the PaintControl event and draw the controls yourself. E.g. the PaintControl help topic contains an example showing how to do that for a TextBox.
Some .NET 2 controls implement the DrawToBitmap method, which you could call from your PaintControl event handler to draw the controls.
Tx2000
Reply #2 - Oct 18th, 2007 at 11:36am
I implemented the DrawToBitmap method succesfully but only work corretly in "overview" control.
Code:
       private void controls_paint (object sender, PaintControlEventArgs e)
           if (e.Node.Control is Control_Notas.Control_Notas )
               Control_Notas.Control_Notas cn = (Control_Notas.Control_Notas)e.Node.Control;
               Rectangle rf = Rectangle.Round(e.Node.Control.DisplayRectangle);
               Bitmap bmp = new Bitmap(rf.Width, rf.Height);
               e.Node.Control.DrawToBitmap(bmp, rf);
               Rectangle rf2 = Rectangle.FromLTRB(0,0,bmp.Width,bmp.Height );
               e.Graphics.DrawImage(bmp, e.PaintRect,rf2, GraphicsUnit.Pixel);
When I launch printpreview, not work correctly.
Thank You.
Reply #3 - Oct 18th, 2007 at 12:10pm
Set DiagramView.PrintOptions.PaintControls = true and it should work when printing / previewing too.
Tx2000
Reply #4 - Oct 18th, 2007 at 12:45pm
Undecided
Not work correctly.
       private void PrintPreview_Button_Click(object sender, EventArgs e)
           this.Vista_Diagrama.PrintOptions.PaintControls = true;
           this.Vista_Diagrama.PrintPreview();
Visual Studio 2005
C#
NET 2.0
Reply #5 - Oct 18th, 2007 at 1:00pm
Isn't the event raised at all, or you don't like how the bitmap is drawn?
Tx2000
Reply #6 - Oct 18th, 2007 at 1:58pm
Example:
Reply #7 - Oct 18th, 2007 at 3:43pm
Set PrintOptions.TargetView = this.Vista_Diagrama before calling the PrintPreview method. The control should do that automatically, but it seems we have omitted it.
Tx2000
Reply #8 - Oct 18th, 2007 at 4:59pm
THANK YOU!
