Very Hot Topic (More than 25 Replies) visio import error (Read 22959 times)
strong_peng
visio import error
Nov 2nd, 2007 at 7:01am
have bought FlowChartX Professional Edition4.1.4,
Write code: report error :-2147467259 , Why?
IVisioImporter* vImport;
HRESULT hr=CoCreateInstance(CLSID_VisioImporter,NULL,
CLSCTX_ALL,
IID_IVisioImporter,(void **)&vImport);
CString strFileName;
strFileName="D:\\work\\test\\testFlow\\testFlow\\1.vdx";
if (SUCCEEDED(hr))
long nPage=0;
BSTR bstrTmp;
bstrTmp =strFileName.AllocSysString();
hr=vImport->GetPageCount(bstrTmp ,&nPage);
if (SUCCEEDED(hr))
CString str;
str.Format("%d",nPage);
AfxMessageBox(str);
}else
CString str;
str.Format("%d",hr);
AfxMessageBox(str);
}else
return;// FALSE;
1.vdx has been send to support@mindfusion.org
Re: visio import error
Reply #1 - Nov 2nd, 2007 at 9:37am
We haven't received any VDX file - please email it again.
strong_peng
Reply #2 - Nov 4th, 2007 at 11:30pm
email is bad,I try again.
my msn code is wangpeng_dragon@hotmail.com,
Could you add my msn code. i transfer it to you .
strong_peng
Reply #3 - Nov 5th, 2007 at 2:22am
I have sent 1.vdx(1.rar) .
Reply #4 - Nov 5th, 2007 at 10:31am
The importer opened your file without any problems here. Do you have the MSXML runtime installed on your system? - it is required in order to parse VDX documents.
strong_peng
Reply #5 - Nov 6th, 2007 at 12:12am
my os is windows xp ,
I Find msxml4.dll  msxml4r.dll in system32.
my code is error?
strong_peng
Reply #6 - Nov 6th, 2007 at 12:37am
i install msxml 4.0 sp2 in my os. but error yet
strong_peng
Reply #7 - Nov 6th, 2007 at 12:39am
my os is  simpl chinese windows xp
strong_peng
Reply #8 - Nov 6th, 2007 at 4:59am
need unicows.dll  ?
Reply #9 - Nov 6th, 2007 at 6:32am
You don't need "unicows.dll".
That code is returned when the importer cannot instantiate the MSXML parser object, or cannot load the VDX file for some other reason, e.g. if you do not have access rights to it. If you have that file opened in Visio, you might need to close it before running the importer.
strong_peng
Reply #10 - Nov 6th, 2007 at 11:51am
i use error file, report error just now.
i use right file, wait some second report error.
i think msxml maybe error
msxml i use 4.0 sp1? it is right?
strong_peng
Reply #11 - Nov 6th, 2007 at 12:02pm
why i forget  CoInitialize(NULL);
but CoCreateInstance success
strong_peng
Reply #12 - Nov 6th, 2007 at 12:05pm
I find
CLSCTX_ALL,
it  load msxml3.0, i think it is error reason.
but how instance msxml4.0
strong_peng
Reply #13 - Nov 6th, 2007 at 12:09pm
vc report
“testvisio.exe”: 已加载“C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls
_6595b64144ccf1df_6.0.3790.2778_x-ww_A8F04F11\comctl32.dll”,未&#211
52;载任何符号。
“testvisio.exe”: 已加载“C:\FcxVisioImport.dll”,未加载&
#20219;何符号。
“testvisio.exe”: 已加载“C:\WINDOWS\system32\msxml3.dll”,未加
载任何符号。
testvisio.exe 中的 0x7c815e02 处最可能的异常: 0xE0000001: 0xe0000001 。
testvisio.exe 中的 0x7c815e02 处最可能的异常: Microsoft C++ exception: _com_error @ 0x0012f2ec 。
strong_peng
Reply #14 - Nov 6th, 2007 at 12:10pm
52;载任何符号。
#20219;何符号。
载任何符号。
