Page Index Toggle Pages: 1 [2] 3  Send TopicPrint
Very Hot Topic (More than 25 Replies) visio import error (Read 22963 times)
strong_peng
Re: visio import error
Reply #15 - Nov 6th, 2007 at 12:12pm
testvisio.exe: loadedC:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6
.0.3790.2778_x-ww_A8F04F11\comctl32.dll,
testvisio.exe: loadedC:\FcxVisioImport.dll,
testvisio.exe: loadedC:\WINDOWS\system32\msxml3.dll,
testvisio.exe  0x7c815e02 : 0xE0000001: 0xe0000001
testvisio.exe  0x7c815e02 : Microsoft C++ exception: _com_error @ 0x0012f2ec
strong_peng
Reply #16 - Nov 6th, 2007 at 12:16pm
I download  FcxVisioImport.dll
From https://mindfusion.eu/FcxVisioImport.zip
strong_peng
Reply #17 - Nov 6th, 2007 at 12:57pm
I have sent msxml2.h .
Reply #18 - Nov 6th, 2007 at 1:52pm
Yes, the Visio importer has been built using the MSXML3 API, which is a very old version and might have some problems when running on a Chinese XP. We will rebuild the importer using MSXML6 later this week and send you an updated dll to try it on your system.
strong_peng
Reply #19 - Nov 7th, 2007 at 12:15am
Thanks for your quick response! We have an important presentation for our client this Friday, so could you please try to rebuild it and send to me before this time at your early convenience? Thanks again and good luck. You're welcome to Beijing for our Olympic Game next year! I'm looking forward to hearing from you!
Reply #20 - Nov 7th, 2007 at 11:38am
Could you first check what is the return value of the ImportPage method? It returns a VARIANT string containing some additional information about the error. I mean the [out, retval] VARIANT parameter, and not the HRESULT integer code.
strong_peng
Reply #21 - Nov 7th, 2007 at 1:36pm
hr=vImport->ImportAllPages(bstrTmp,(LPDISPATCH)m_FlowChart.GetControlUnknown(),&
vResult);
vResult  is empty.
strong_peng
Reply #22 - Nov 7th, 2007 at 1:43pm
maybe you can give me your msxml3.dll
i try.
strong_peng
Reply #23 - Nov 7th, 2007 at 1:44pm
hr=vImport->ImportPage(bstrTmp,(LPDISPATCH)m_FlowChart.GetControlUnknown(),0,&vR
esult);
hr=vImport->ImportPage(bstrTmp,(LPDISPATCH)m_FlowChart.GetControlUnknown(),1,&vR
esult);
vResult is empty.
Reply #24 - Nov 7th, 2007 at 1:55pm
I can see only one case when the returned VARIANT result is empty - when the QueryInterface for the flowchart pointer fails. Instead of casting the IUnknown flowchart pointer to LPDISPATCH, try calling QueryInterface as shown in this thread:
http://mindfusion.org/cgi/Forum/YaBB.pl?board=fcx_news;action=display;num=112352...
strong_peng
Reply #25 - Nov 7th, 2007 at 11:34pm
I tried it ,
vResult is empty also.
Reply #26 - Nov 8th, 2007 at 6:46am
Try this version of the importer:
https://mindfusion.org/_temp/FcxVisioImport.zip
It should return an error description string in all cases.
strong_peng
Reply #27 - Nov 8th, 2007 at 10:16am
Error loading xml content
Reply #28 - Nov 8th, 2007 at 11:45am
This version uses MSXML6:
https://mindfusion.org/_temp/FcxVisioImportXml6.zip
Let me know if you are still getting error messages. Because of differences between MSXML3 and MSXML6, we had to change near 100 XML query expressions and haven't tested the importer much yet, so this could result in some new problems  Undecided
strong_peng
Reply #29 - Nov 8th, 2007 at 12:43pm
also is
