Page Index Toggle Pages: 1 2 [3]  Send TopicPrint
Very Hot Topic (More than 25 Replies) visio import error (Read 22962 times)
Re: visio import error
Reply #30 - Nov 8th, 2007 at 1:50pm
Try tracing the following code:
#import "MSXML6.dll" named_guids
bool File2String( LPCTSTR FileName, CString & FileContent )
     DWORD dwSize = 0, dwReadSize = 0;
     HANDLE hFile = NULL;
     HFILE hfOpened = NULL;
     OFSTRUCT oOfs;
     try
           ZeroMemory(&oOfs, sizeof(oOfs));
           FileContent.Empty();
           hFile = (HANDLE) OpenFile(FileName, &oOfs, OF_READ);
           if (hFile!=INVALID_HANDLE_VALUE)
                 dwSize = GetFileSize(hFile, NULL);
                 if ( dwSize == 0 )
                       CloseHandle(hFile);
                       return false;
                 ReadFile(hFile,FileContent.GetBuffer(dwSize),dwSize,&dwReadSize,NULL);
                 CloseHandle(hFile);
                 FileContent.GetBufferSetLength(dwSize);
           else
                 ATLTRACE("Error %i opening file: %s\n", GetLastError(), FileName);
                 return false;
     catch ( ... )
           return false;
     return true;
CString sXML;
File2String(path_to_your_vdx, sXML);
MSXML2::IXMLDOMDocument2Ptr m_xmldoc;
m_xmldoc.CreateInstance(MSXML2::CLSID_DOMDocument60);
VARIANT_BOOL success = m_xmldoc->loadXML((LPCTSTR) sXML);
Where does it fail?
strong_peng
Reply #31 - Nov 9th, 2007 at 7:30am
VARIANT_BOOL success = m_xmldoc->loadXML( sXML.AllocSysString());
report  error .
VARIANT_BOOL success = m_xmldoc->load("C:\\1.vdx");
is ok
Reply #32 - Nov 9th, 2007 at 7:55am
Here is a version that loads the file using XmlDocument->Load:
https://mindfusion.org/_temp/FcxVisioImport2.zip
We used OpenFile in order to be able to load the file while it is opened in Visio. With that latest version that won't be possible, because XmlDocument->Load requires exclusive access to the file for some reason.
strong_peng
Reply #33 - Nov 9th, 2007 at 8:05am
I suggest  use the load with msxml3 and msxml6
strong_peng
Reply #34 - Nov 9th, 2007 at 8:13am
thanks a million. transfer ok, why so diffrense with source visio,
Reply #35 - Nov 9th, 2007 at 11:05am
VisioImporter does not support custom Visio shapes, and it support only a few of the standard Visio shape palettes, e.g. Flowchart, Block Diagram, Organization Chart and Database. For other shapes, you can handle the BoxImported event and set the Shape or Picture of the imported box according to the VisioShapeName parameter.
