Normal Topic Allow User To Change Column Width (Read 1454 times)
Aaron
Looking for support
Nov 26th, 2007 at 11:26am
Hi
Am I correct when I say it's not supported in FC.NET 4.3.1 to allow users to change each column's width (in a table) by dragging the lines? So you'd get that VSplit cursor I think it is and you'd be able to drag the column border, shrinking or growing the column dynamically.
Is it supported in FC.NET 5.0?
If it is supported in 4.3.1 how will I use it? If not, any ideas on how to implement it quickly?
Very sorry if I haven't searched enough.
Kind regards
Aaron
Re: Allow User To Change Column Width
Reply #1 - Nov 26th, 2007 at 11:32am
This is a popular request and we are going to implement it in the one of the 5.0.x releases. You will need to handle the MouseDown event and do some hit-testing to determine whether the mouse is over the border between two columns, and if so, resize the columns from the MouseMove handler.
