Normal Topic FlowChart Version 5 Serialization-Deserialization (Read 4218 times)
slorenzo
Nov 27th, 2007 at 8:41am
Hi, I have a problems with version 5 when I serialize and deserialize FlowChart.
I use a custom class in a object tag and I use this code to Serialize FlowChart:
  _diagram.SerializeTag += new SerializeTagEventHandler(this.SerializeTag);
  _diagram.SaveToXml(fileName);
  private void SerializeTag(object sender, MindFusion.Diagramming.SerializeTagEventArgs e)
		object tag = null;
		string xmlTag = "";
		string stringRepresentation = "";
		e.Handled = true;
		if (e.Object is DiagramItem)
		    tag = (e.Object as DiagramItem).Tag;
		    if (tag is VectorNodeProps)
			  xmlTag =Util.ObjectXMLSerializer(.....
		    if (tag is string)
			  xmlTag = (string)tag;
		if (e.Object is Diagram)
		    tag = (e.Object as Diagram).Tag;
		    xmlTag = Util.ObjectXMLSerializer(....
		if (tag != null)
		    stringRepresentation = tag.GetType().ToString();
		    stringRepresentation += ";";
		    stringRepresentation += xmlTag;
		XmlNode repNode = e.Context.XmlDocument.CreateTextNode(stringRepresentation);
		e.Representation.AppendChild(repNode);
And then I use this code to Deserialize:
 _diagram.DeserializeTag += new SerializeTagEventHandler(this.DeserializeTag);
 _diagram.LoadFromXml(fileName);
 private void DeserializeTag(object sender, MindFusion.Diagramming.SerializeTagEventArgs e)
 XmlText textNode = e.Representation.LastChild as XmlText;
		string stringRep = textNode.Value;
		int pos = stringRep.IndexOf(";");
		if (pos == -1)
		    return;
		string type = stringRep.Substring(0, pos);
		string xml = stringRep.Substring(pos + 1);
		object tag = null;
		Type t = Type.GetType(type);
 if (t == typeof(MyClass))
		  tag = Util.ObjectXMLSerializer(......)
   if (t == typeof(string))
		    tag = xml;
		if (e.Object is Group)
		    ((Group)e.Object).Tag = tag;
		else if (e.Object is DiagramItem)
		    ((DiagramItem)e.Object).Tag = tag;
		else if (e.Object is Diagram)
		    ((Diagram)e.Object).Tag = tag;
The tags are correctly serializated, but wen I try to deserialize I get this exception:
System.FormatException was caught
  Message="Input string was not in a correct format."
  Source="MindFusion.Diagramming"
  StackTrace:
	 at MindFusion.Diagramming.Diagram.LoadFromXml(XmlDocument document)
	 at MindFusion.Diagramming.Diagram.LoadFromXml(String fileName)
	 at Gui.ViewFormControls.DataFlowControl.LoadDataFlow(String fileName, Diagram _flowChart) in ....
Can anyone help me!!!
Thanks Lorenzo
Re: FlowChart Version 5 Serialization-Deserializat
Reply #1 - Nov 27th, 2007 at 10:19am
You must set e.Handled = true. Otherwise the diagram will try to deserialize the tag on its own and will probably not recognize your tag format.
slorenzo
Reply #2 - Nov 27th, 2007 at 10:44am
I have already try to set e.Handled = true in the Deserialize code, but after the deserealization the tags are null, even if they are correctly assigned to the objects.
Thanks, lorenzo
Reply #3 - Nov 27th, 2007 at 10:50am
Now you must assign the deserialized object to e.Tag, and not directly to the item's Tag. The value you set in e.Tag is later assigned to the item.
slorenzo
Reply #4 - Nov 27th, 2007 at 10:59am
Thanks now work correctly  Smiley
slorenzo
Reply #5 - Nov 27th, 2007 at 11:49am
Sorry another question, it's possible to disable images serialization?
Reply #6 - Nov 27th, 2007 at 1:07pm
That's not possible. Instead, you could use the SaveToXml(XmlDocument) to save the diagram, remove all "/Image" XML elements, and them use XmlDocument.Save the save XML file.
