Normal Topic Scroll to view center (Read 2419 times)
due
Nov 28th, 2007 at 8:19am
I have to center a diagram element in the middle of the view. My following (scroll) approach does not do the right thing.
	//extract view state
	RectangleF viewBounds = diagramView.Bounds;
	float viewWidth = viewBounds.Width;
	float viewHeight = viewBounds.Height;
	float viewX = viewBounds.X;
	float viewY = viewBounds.Y;
	//extract document state
	RectangleF docBounds = diagram.Bounds;
	float docWidth = docBounds.Width;
	float docHeight = docBounds.Height;
	//scrolling necessary
	if (docWidth >= viewWidth &&
	    docHeight >= viewHeight) return false;
	//prepare scrolling
	float scrollX = -1;
	float scrollY = -1;
	//scrolling X necessary
	if (viewWidth < docWidth) {
	  float maxScrollX = docWidth - viewWidth;
	  float centerX = rectangle.X + (rectangle.Width / 2);
	  scrollX = centerX - (viewWidth / 2);
	  if (scrollX < 0) scrollX = 0;
	  if (scrollX > maxScrollX) scrollX = maxScrollX;
	} else {
	  //take current value
	  scrollX = viewX;
	//scrolling Y necessary
	if (viewHeight < docHeight) {
	  float maxScrollY = docHeight - viewHeight;
	  float centerY = rectangle.Y + (rectangle.Height / 2);
	  scrollY = centerY - (viewHeight / 2);
	  if (scrollY < 0) scrollY = 0;
	  if (scrollY > maxScrollY) scrollY = maxScrollY;
	} else {
	  scrollY = viewY;
	//do scrolling
	diagramView.ScrollTo(scrollX, scrollY);
What is here the problem or how can I achieve the centering of diagram elements?
Re: Scroll to view center
Reply #1 - Nov 28th, 2007 at 1:34pm
The BringIntoView method of DiagramView centers the item if it is not in the visible area. The code looks like this:
public void BringIntoView(DiagramItem item)
	if (item != null)
		// Get the currently visible document area
		RectangleF rcClient = ClientToDoc(ClientRectangle);
		// Check if the objects is entirely in the visible area
		RectangleF rcObj = item.GetRepaintRect(false);
		if (rcObj.Left < rcClient.Left || rcObj.Right > rcClient.Right ||
			rcObj.Top < rcClient.Top || rcObj.Bottom > rcClient.Bottom)
			// Scroll to center the object in the visible area
			float cx = (rcObj.Left + rcObj.Right - rcClient.Width) / 2;
			float cy = (rcObj.Top + rcObj.Bottom - rcClient.Height) / 2;
			if (cx < diagram.Bounds.Left)
				cx = diagram.Bounds.Left;
			else if (cx > diagram.Bounds.Right - rcClient.Width)
				cx = diagram.Bounds.Right - rcClient.Width;
			if (cy < diagram.Bounds.Top)
				cy = diagram.Bounds.Top;
			else if (cy > diagram.Bounds.Bottom - rcClient.Height)
				cy = diagram.Bounds.Bottom - rcClient.Height;
			ScrollTo(cx, cy);
You could just remove the "if" statement that checks if the item is not already in the view. Centering will not work for items that are near the diagram boundary, because you cannot scroll to a position outside diagram.Bounds.
due
Reply #2 - Nov 30th, 2007 at 8:44am
Fine, it works. Thx!
Problem:
You have to use
diagramView.ClientToDoc(diagramView.ClientRectangle) instead of
diagramView.Bounds
to extract view bounds.
