Normal Topic NodeCreated Event & UndoManage (Read 1361 times)
Alex
Dec 4th, 2007 at 5:50am
I don't know if this is a bug or it is intended.
I create a node via drag&drop. Then I call the Undo()-method of the UndoManager. The NodeDeleted Event is fired (which is correct I would say).
If I call the Redo()-method, the formerly deleted node appears on the diagram but the is no NodeCreated-Event fired (which I do'nt understand).
Any suggestions?
Best regards,
Alex
Re: NodeCreated Event & UndoManage
Reply #1 - Dec 4th, 2007 at 6:39am
Most of the events are raised only in response to users actions. The Deleted event is one of the few exceptions - it is raised every time an item is deleted - never mind whether it is programmatically, interactively, or internally by Flowchart.NET. If you need to detect that an item is added due to undo/redo, you will need to handle the ActionUndone and ActionRedone events and check the type of the action that is passed as an argument to these events.
