Normal Topic NetDiagram ZoomToFit (Read 1859 times)
KBalquis
Senior developer
Dec 4th, 2007 at 12:39pm
am using the following::
    function onAppletStarted()
    var fcApplet = <%= wfGraph.AppletElement %>;
     fcApplet.width = 728;
     fcApplet.height = 200;
     fcApplet.zoomToFit();
am getting Javascript error:
"Object doesn't support this property or method.
please advise
Kamel Balquis
Re: NetDiagram ZoomToFit
Reply #1 - Dec 4th, 2007 at 12:53pm
fcApplet is an instance of the FlowChartApplet class and zoomToFit is a method of the FlowChart class.
The applet contains a FlowChart instance which you can access via the getFlowChart() method, so the script should look like this
	var fc = fcApplet.getFlowChart();
	fc.zoomToFit();
