Normal Topic Setting Mouse Cursor (MousePointer) (Read 3749 times)
baron
Dec 5th, 2007 at 5:29pm
I need to set the mouse cursor that displays when the user moves the mouse over the Chart regardless of where he is or what he is doing (i.e. in VB its MousePointer = x)
When I set it in the container control the flowchart sometimes shows the new cursor but seems to reset it all the time back to normal.
Is there a method of setting the default cursor on the chart directly?
Re: Setting Mouse Cursor (MousePointer)
Reply #1 - Dec 6th, 2007 at 6:14am
The control keeps a list of mouse cursors to display in various situations, and changes them automatically when needed, e.g. when the user moves the mouse over a selection handle. You can set these cursors by calling the FlowChart.SetMouseCursor method. It should be easy to add a new member to that list, which will override all other cursors when set. I will post here a link to the updated dll here when that's ready.
baron
Reply #2 - Dec 6th, 2007 at 8:07am
I saw that API but I also meant a way to set the cursor when the mouse is over blank space etc. I.e. global for the whole chart area.
Reply #3 - Dec 6th, 2007 at 8:29am
You could use SetMouseCursor(mcPointer) for the whole chart area, but the cursor will still change when you move it over a box.
Reply #4 - Dec 6th, 2007 at 12:08pm
We have added a mcCurrent cursor type which you can set via SetMouseCursor:
https://mindfusion.org/_temp/fc_cursors.zip
It will override all other cursors; they won't be displayed even when the mouse is over a selection handle, nor during modification when different cursor images are used to indicate whether the operation is allowed. To revert to the original behavior, set the mcCurrent cursor back to 0.
baron
Reply #5 - Dec 10th, 2007 at 2:43pm
Thanks!
And may I interject here that I am very impressed with your level and speed of support.
Reply #6 - Dec 10th, 2007 at 4:45pm
