Normal Topic How to stop diagram from showing no-drop cursor? (Read 2171 times)
consolejoker
Dec 17th, 2007 at 10:35pm
Whenever I start to drag on the diagram control, regardless of what mode its in, it momentarily shows the no-drop cursor, or no-op cursor, the black circle with a line through it.
This is really annoying, its only there for a split second and makes absolutely no sense to be displayed.
Frankly its a showstopper, if I can't remove it, I will have to consider another library/framework.
consolejoker
Re: How to stop diagram from showing no-drop curso
Reply #1 - Dec 17th, 2007 at 10:40pm
Found something that works, DissallowCursor set to true seems to do the trick.
Not sure why it shows this icon when it can clearly draw an icon.
Reply #2 - Dec 18th, 2007 at 6:16am
The control displays the stop cursor when an item creation or modification cannot be completed at the current location for some reason. Items of zero width or height (or close to zero) are not allowed,  so you see the stop cursor unless you move the mouse away from the point where you started drawing. You will see the cursor again if you move the mouse back to the start point, or if you try to resize an item to zero width or height.
