Normal Topic Arrow Shadow Colour (Read 1420 times)
pelion
Arrow Shadow Colour
Dec 6th, 2007 at 2:45am
Hi
I am looking for a way to set the default ArrowShadow Colour for all arrows on the FlowChart, not individually but globally, the same way that box shadow can be set by chart.ShadowColor.
Any ideas
Cheers
Re: Arrow Shadow Colour
Reply #1 - Dec 6th, 2007 at 7:11am
From what I can see in the code, ShadowColor is initialized in the constructor of the base DiagramItem class (ChartObject in V4), so this should work the same both for nodes and links. If you want to use a different shadow color for links, you could assign it from the InitializeLink event.
