Normal Topic Box Deselected event (Read 2844 times)
pelion
Dec 6th, 2007 at 3:21am
I appear to be fhaving strange behaviour around the Box deselected event where it appears on to be firing when its deselection is caused by another box being clicked.
When the background chart is clicked, the event does not fire, leaving me unable to clean up the UI from the previous selection
Again any help greatly appreciated
JC
Update
________
This behaviour is probably as I am doing a chart.Selection.clear on Mouse down on the chart, if the selected area contained no boxes.
I am now trying to get the Deselected event to fire by looping through the Selection.Boxes in a reverse for loop, and setting the Box.Selected property to be false. This does not work either,
Re: Box Deselected event
Reply #1 - Dec 6th, 2007 at 7:15am
You could move the BoxDeselected code to a method, then call this method from BoxDeselected, and for all selected boxes before calling Selection.Clear.
pelion
Reply #2 - Dec 6th, 2007 at 7:30pm
So you are agreeing that the event shouldn't fire in a background chart click event?
I realised, with a touch of embarrasment, last night that it was obvious what I was looking for (when is a box being deselected when I click the background) was happening when I was clearing the selection programatically  Embarrassed
I already had a 'Deselect Box' style method called from the BoxDeselecting event, so I just called it on mouse down when NodeAt(...) was null.
Thanks for your help
Reply #3 - Dec 7th, 2007 at 6:55am
Deselected should be raised when you click the chart background and the selection state of a box actually changes. Isn't it raised in your application (when you do not call Selection.Clear)?
pelion
Reply #4 - Dec 13th, 2007 at 9:45pm
Stoyo wrote on Dec 7th, 2007 at 6:55am:
Unfortunately not, no
Reply #5 - Dec 14th, 2007 at 5:58am
Try this test application:
https://mindfusion.org/_temp/DeselEventTester.zip
From what I can see, BoxDeselected is raised as expected. You might copy your other event handlers to that project, one at a time,  leaving only the selection-related logic in them. This should show what exactly prevents BoxDeselected from being raised.
