Normal Topic Jar permanently on the client machine (Read 3259 times)
koosala
Java Happens
Dec 10th, 2007 at 4:41am
Is there any way I can make JDiagram.jar get permanently installed on the client side and I mention on every access to a diagramming page to point to that Jar?
I am interested in this because, there are different pages where I will be using JDiagram.jar. So, they have different URLs.
I don't want JDiagram it getting downloaded separately for each of these URLs.
Praveen
Re: Jar permanently on the client machine
Reply #1 - Dec 10th, 2007 at 6:53am
Instead of having a different .jar copy for each of your pages, you could keep the .jar file in a shared location on your server and set the path to it in FlowChart.JarLocation. That will ensure that the JRE class loader will always use the cached version instead of downloading the .jar again.
koosala
Java Happens
Reply #2 - Dec 17th, 2007 at 3:06am
The jar can also be hosted from unrelated applications (different servers even). Can a copy of jar be kept on the client and I make all of these Jars point to that copy of the jar?
I don't mind using JDiagram.jar directly instead of NetDiagram, if it helps me in doing this.
Praveen
Reply #3 - Dec 17th, 2007 at 7:32am
If your clients have the jdiagram.jar available on the local system and it is in the Java CLASSPATH, then setting JarLocation to an empty string should make the Java class loader load the applet from the local system. You might have to create an installer that copies the JDiagram.jar somewhere locally and adds the .jar to the class path.
