Normal Topic Multiple Day items (Read 3441 times)
alanmcgeough
Multiple Day items
Dec 17th, 2007 at 1:19pm
Hi i just have a quick question what is the best way to have a item covering 2/3 or multiple days if is it possible to set the endtime for the item to the next day or 3 days from now or what is the best solution to this.
Re: Multiple Day items
Reply #1 - Dec 18th, 2007 at 5:46am
You have to set the EndTime of the item to the appropriate date. For example, if you want the item to end three days after it has started, use the following code:
item.EndTime = item.StartTime.Add(TimeSpan.FromDays(3))
« Last Edit: Dec 18th, 2007 at 11:33am by Meppy »
alanmcgeough
Reply #2 - Dec 18th, 2007 at 11:12am
when i have a multiple day event is there any way that  i can place it on the _schedule showing the item across the  full day and not as all day event event. for example showing the item booked across a number of days
i have tried using the
_clickedItem.StartTime.Add(TimeSpan.FromDays(numDays))
but instead of showing the item on the _schedule it shows it on top of the _schedule for that day as all dayevent
can i disable this all day event so that the item can be draw across the day.
Reply #3 - Dec 18th, 2007 at 11:39am
Try setting the Calendar.TimetableSettings.EnableDayItems property to Disabled. This will prevent items longer than one day from displaying in the all-day header.
alanmcgeough
Reply #4 - Dec 18th, 2007 at 12:46pm
yes thats great thanks for that  i tried that and it worked fine but the item only went to the end of the day it was on even though the end date spread over 3 days. I would expect it to cover the 3 days.
thanks again
Reply #5 - Dec 18th, 2007 at 1:34pm
The item should span all three days. Can you send me a screenshot of what is happening at your side, so that I can see what might be wrong?
