Normal Topic Does FlowChart.NET work with Mono on Linux? (Read 4045 times)
consolejoker
Dec 21st, 2007 at 9:12pm
I can't stress how great it would be to have this feature, does it exist now?
Re: Does FlowChart.NET work with Mono on Linux?
Reply #1 - Dec 22nd, 2007 at 7:12am
It seems Mono implements System.Drawing and Windows.Forms libraries. We'll see if we can build the FlowChart.NET assemblies using the Mono version of the libraries and let you know the result.
Reply #2 - Dec 29th, 2007 at 10:19am
We've tried running one of the sample projects under the Mono version that comes with OpenSuse 10.3. This displayed a "NOT IMPLEMENTED YET: GdipTransformPoints(...)" in the MonoDevelop output pane and the application crashed. We'll check if there is some newer version of Mono that implements that method, or will try to replace TransformPoints with several TransformPoint calls.
Reply #3 - Jan 3rd, 2008 at 12:49pm
We have made some progress - now you can load the control in a Mono application, and it works fine with MeasureUnit == Pixel, as long as the scroll position and zoom factor do not change 8) Apparently translate- and scale- transformations are not yet fully implemented in the Mono' System.Drawing library. We'll see if we can work around that too.
By the way, is anyone else interested in a Mono version of Flowchart.NET?
consolejoker
Reply #4 - Jan 3rd, 2008 at 3:22pm
I'm surprised simple transforms aren't there yet, those are probably 10 minutes of work on their part.
I guess I am the only vocal proponent of FlowChart.NET in mono at the moment. There must be others who are not using this board, but who knows.
pelion
Reply #5 - Jan 9th, 2008 at 8:23pm
In answer to Stoyan,
We have no immediate use for Mono FlowChart libraries, however it would be fantastic to know they work when we (get around to) porting to Linux, it would take an enormous chunk out of our architecture effort
Serge
Reply #6 - Mar 16th, 2009 at 7:45pm
We are very interested in getting FlowChart.net to work in Mono for Linux. In my experience, it already works in Mono in Windows.
Thank you,
Serge
Reply #7 - Mar 17th, 2009 at 9:08am
We'll check it with the latest Mono on Linux next week.
