Normal Topic How can you set column width on table node? (Read 1786 times)
consolejoker
Dec 29th, 2007 at 3:09am
I have a simple table node with 2 columns. But the first column is much wider than I need it to be. I can't seem to find a way to set the width for column 'n' on a given table.
Re: How can you set column width on table node?
Reply #1 - Dec 29th, 2007 at 5:40am
Try this:
table.Columns[0].ColumnStyle = ColumnStyle.FixedWidth;
table.Columns[0].Width = 10;
consolejoker
Reply #2 - Dec 30th, 2007 at 12:18am
Thanks that did the trick! Man I didn't even know about that columns property, I was staring at it all day.
I need to pour over the manual a bit more Smiley
