Normal Topic ValidateAnchorPoint does not seem to fire (Read 2993 times)
consolejoker
Dec 30th, 2007 at 9:20pm
I hover a link with mouse down over another anchor point and then release. The event doesn't seem to fire. I have set allow incoming and outgoing links to the anchor.
Both nodes are instances of the same configured table.
Re: ValidateAnchorPoint does not seem to fire
Reply #1 - Jan 1st, 2008 at 5:12am
What ConnectionStyle are you using? And have you assigned the anchor points to Table.AnchorPattern, Table.RowAnchorPattern, or Row.AnchorPattern?
consolejoker
Reply #2 - Jan 1st, 2008 at 3:28pm
I assigned it to the node's anchorpattern.
As far as I can tell I am not explicitely setting the connectionstyle anywhere in my code, so I set it to table.RowANchorPattern, which ended up throwing a wierd exception outside of my code scope and caught from within Program.Run(form)... Same with Row.AnchorPattern.
consolejoker
Reply #3 - Jan 1st, 2008 at 7:39pm
Ok I think I fixed it, the problem was that I was setting the row index beyond the number of rows I had.
Anyway the problem I have now is that I set e.Cancel to true but the anchoring operation succeeds. Is there a proper way to cancel the operation other than e.Cancel = true?
consolejoker
Reply #4 - Jan 1st, 2008 at 8:36pm
It seems to work if I handle OnLinkCreating and set cancel to true.
Reply #5 - Jan 2nd, 2008 at 6:49am
The default ConnectionStyle is Rows, so you must assign to either the Table.RowAnchorPattern or Row.AnchorPattern if you need the links to connect to the points you specify. Rejecting all points will just make the link connect to the nearest point from the table border. So you got that right, you must cancel the operation from LinkCreating if you need to prevent the link creation.
