Normal Topic Location changes and recurrence (Read 1591 times)
elpuerco
Time?  What's time matta
to a pig?
Feb 12th, 2008 at 1:41pm
Can you try this and see if you can replicate please?
Have two locations, whse1 and whse2
select whse2 and add an item to a timetable view on any Monday you like.
modify the item to be a recurrence to run every day for 5 occurences
you should now see 5 items in a row on the timetable view
(I also have a monthview which highlights the days with items preent on the timetable view)
Open the item on Tuesday, single occurence only.
Change the location to whse1 and save.
You now have 4 items in the timetable view with a blank where the Tuesday item was.
The highlight is also gone.
Now select whse1 and see that the highlight for the Tuesday is lit up to show there is an item there.
BUT the item doe not display on the timetable view?
The item is in the item table with an occurence index of 2
is this normal.
Is there a way to prevent a user splitting a recurrence across locations?
Ideally I would want to stop them from oing this kind of thing.
Re: Location changes and recurrence
Reply #1 - Feb 12th, 2008 at 2:52pm
This appears to be a bug - not showing the exceptions of recurring items whose resource has been changed. I am going to fix this and send you an upgrade. However, you can prevent users from changing the location of (recurring) items by handling the ItemModifying event.
