Normal Topic Naming AnchorPoints (Read 1586 times)
Bruno
There's always one more
bug.
Naming AnchorPoints
Feb 12th, 2008 at 2:50pm
I use FlowChart.NET to display Function blocks as ShapeNodes, with Input/Output represented by AnchorPoints and interconnect them by DiagramLinks.
Is there a way to display the name of every AnchorPoint in the shape itself, rather than using a ToolTip ?
Thanks in advance. ???
Re: Naming AnchorPoints
Reply #1 - Feb 12th, 2008 at 4:14pm
You could set the points MarkStyle to Custom, then handle DrawMark and draw the AnchorPoint name using e.Graphics.DrawString.
Bruno
bug.
Reply #2 - Feb 13th, 2008 at 11:13am
it was a little longer than setting a boolean property value, but it's working just fine.
Thanks a lot Stoyo
8)
