Normal Topic Problem arranging layout (Read 1852 times)
francisco.leonardo
Feb 12th, 2008 at 4:49pm
Im using the TreeLayout class and calling the arrange method to adjust the diagram's links and tablenodes.
In some cases, links are crossing tablenodes and tablenodes are overlapping each other.
I tried to not set the root property of the treelayout class, but still don't work.
Is there any property to set or call method to fix my problem?
Re: Problem arranging layout
Reply #1 - Feb 12th, 2008 at 5:28pm
TreeLayout really works only with trees. If you run it on a more complex graph, links that are not part of the graph's spanning tree are ignored. You could call the Route method of such links to fix them.
francisco.leonardo
Reply #2 - Feb 12th, 2008 at 5:43pm
But some tablenodes still overlaps other tablenodes. I thought that the component had a collision detection algorithm or something like.
Reply #3 - Feb 12th, 2008 at 5:51pm
You might have to set larger NodeDistance and LayerDistance values.
