Normal Topic Obstacles in containers (Read 1994 times)
SavyCat
Feb 19th, 2008 at 12:28pm
Hi online. I was wondering if anyone could give me advice on how to use routing inside a container when the container itself must be an obstacle. So - for example you have nested containers, and shapes inside those containers. If i make the sub-container 'Obstacle' property false - then the routing is applied to the shape nodes inside; however if i set the property to true, the routing is ignored. This is undesirable though, because the sub-container still needs to be an obstacle to the other containers links within the same parent container. I hope this makes sense. Any ideas? Thanks Smiley
Re: Obstacles in containers
Reply #1 - Feb 19th, 2008 at 1:32pm
We will have to alter the routing algorithm so that it marks only the container borders as obstacles in the routing grid. We'll try to implement this for the next release.
SavyCat
Reply #2 - Feb 19th, 2008 at 1:53pm
Thanks Stoyo! You are the man  8)
Reply #3 - Feb 22nd, 2008 at 8:46am
Try this version:
https://mindfusion.org/_beta/ctr_routing.zip
Now if a container node is set as an obstacle, only it borders are marked as obstacles in the routing grid.
