Normal Topic MultiSelection problems (Read 2542 times)
wangqaa
Feb 20th, 2008 at 5:14am
   In the same flowchart, Some of the boxes
can't multiSelect.  But some of other boxes or arrows can.
    I can't find out what problems. Do you have
some suggestion to check or debug.
thanks,
Re: MultiSelection problems
Reply #1 - Feb 20th, 2008 at 7:14am
Check whether the boxes are Locked by some chance, and whether changing the Diagram.Selection.IncludeItemsIfIntersect  property makes any difference.
wangqaa
Reply #2 - Feb 20th, 2008 at 8:17am
I find out the problem or bug.
the code behind set some box as selected.
but the clinet result shows not selected.
I don't know why it not reflect the code behind.
(boxes should view as selected)
but When I don't use the Selected method.
It can use multiselection.
thanks~
Reply #3 - Feb 20th, 2008 at 12:51pm
What code behind - are you using our NetDiagram control, or FlowChart.NET loaded in a web page via the html OBJECT element?
wangqaa
Reply #4 - Feb 20th, 2008 at 11:36pm
Just like below
foreach(Box box in fcTemp.Boxes)
    box.Selected=true;
We use "FlowChart.NET loaded in a web page via the html OBJECT element"
I exported  fcTemp as xml file and use your demo
tool. It will show right.(all boxes in fcTemp are selected)
but in web page not.
Reply #5 - Feb 21st, 2008 at 6:51am
If it works fine in the demo, you might compare the FlowChart's properties in the demo with the ones in your web page. There might be several ways to hide the selection handles, for example using HandlesStyle == Custom and not handling the DrawHandles event in the web page, or setting the selection handles color properties to the background / transparent color.
