Hot Topic (More than 10 Replies) Delete node programmatically (Read 8163 times)
mjweyland
Re: Delete node programmatically
Reply #15 - Mar 21st, 2008 at 2:59pm
Ok. I found my problem.
I was explicitly testing on the type of object in the selection items and was testing against "Box". With the new version it should be of type "ShapeNode"  when I made this change things are responding as expected.
My apologies for the confusion.
Reply #16 - Mar 21st, 2008 at 3:01pm
This is impossible if DelKeyAction is really set to None. Check if you aren't accidently setting it to ActiveItem/Selection at some point in your code, or if the nodes aren't deleted from some other event handler.
