Normal Topic Resetting RecurrenceState of Modified Items (Read 1518 times)
BudMan
Credidi me felem vidisse
Mar 8th, 2008 at 10:56pm
I have an Appointment item on my calendar with a Recurrence pattern as follows: Daily, for 3 occurrences. When the user changes the Start/End times of one by dragging the mouse, I want them all to change accordingly. I am using the Calendar's ItemModified event handler to do this with the following code:
appt.Recurrence.Master.StartTime = appt.StartTime
       appt.Recurrence.Master.EndTime = appt.EndTime
This all LOOKS fine. But when I get done, the item I resized has a RecurrenceState of Exception. I want it to revert to just 'regular' Occurrence, like the other items. What is the best way to do this?
Re: Resetting RecurrenceState of Modified Items
Reply #1 - Mar 10th, 2008 at 7:47am
Calling the ClearExceptions method of a Recurrence object should remove all exceptions associated with that recurrence.
