Normal Topic ScrollBar Question (Read 1430 times)
Glacier
ScrollBar Question
Mar 10th, 2008 at 3:46pm
HI,
I'm trying to add dates to the control when the scroll bar has reached its limit. In ResourceView when the HScroll bar has hit its limit i'd like to add
one day to the control. So far there is the code i'm using:
if(ScheduleC.GetLastVisibleDate()>=ScheduleC.EndDate)
    ScheduleC.Date=ScheduleC.Date.AddDays(1);
    ScheduleC.EndDate=ScheduleC.EndDate.AddDays(1);
e.NewValue=ScheduleC.HScrollPos;
I'm trying to keep a range of 7 days in the Resource View only. The code is located in the HScroll event. The issue arrises when I hold down the ScrollButton on the right side. Then the ScrollBar position appears back at the end of the scroll bar and starts to constantly advance dates. Is there a way to change this behavior?
Re: ScrollBar Question
Reply #1 - Mar 10th, 2008 at 4:01pm
Have a look at the UnlimitedScrolling sample installed with Planner.NET. It demonstrates how to achieve the very same effect under WeekRange view. You have to modify the following things in order to make it work under Resource view:
1) Change the view to Resource.
2) Handle the HScroll event instead of the VScroll.
3) Compare to the HScrollPos instead of the VScrollPos in the event handlers.
4) Advance by 1 day, instead of 7.
