Normal Topic Example needed for BoxTextEdited (Read 2255 times)
sjones665
Mar 10th, 2008 at 3:53pm
Do you have any example code on how to use the BoxTextEdited event with ClientSideMode set to JavaApplet?
I am reviewing your trial version and can't seem to figure out how detect when the text in a box has been edited.
Thanks in advance!
Scott
Re: Example needed for BoxTextEdited
Reply #1 - Mar 10th, 2008 at 4:03pm
There aren't any server-side events raised from JavaApplet mode. You could detect that the box has been edited on the client side using the LeaveInplaceEditScript javascript event, e.g. create a function like this
function LeaveInplaceEdit(box, changeAccepted)
and assign its name to the FlowChart.LeaveInplaceEditScript property.
sjones665
Reply #2 - Mar 10th, 2008 at 5:25pm
So, how then do I make the server side ASP.NET code aware of the Box text change? Sorry if I'm being dense.
Reply #3 - Mar 10th, 2008 at 5:39pm
You can call a web service and process the change on the server, as shown in the OrgBrowser sample project. Another option is to gather the IDs of all boxes modified on the client side in some hidden field, and inspect them upon postback.
We could also add a property that when enabled will make the control post the page and raise a server side event after the user edits some text.
