Hot Topic (More than 10 Replies) Flowchart.net v.s NetDiagram (Read 10467 times)
rolend
Jun 13th, 2007 at 4:45am
what different between flowchart.net v.s. NetDiagram?
We use flowchart.net to implement ASP.net solution , but we suffer from "Automation" problem on IE with dot.net 2.0 , could we transfer to netDiagram easily?
Re: Flowchart.net v.s NetDiagram
Reply #1 - Jun 13th, 2007 at 5:25am
NetDiagram uses a Java applet to implement interaction on the client side. This provides for wider browser and OS support. It also handles the transfer of data between the applet and the server automatically, as opposed to the webchart / flowchart.net approach of requiring you to use SaveToString, LoadFromString and html hidden fields.
The server-side API of the two controls is almost the same, but the client side API is different. So it depends on how much client-side code you have how easy it will be to move to NetDiagram.
rolend
Reply #2 - Jun 13th, 2007 at 5:59am
Does  the function of Flowchart.net v5 map to NetDiagram?
Reply #3 - Jun 13th, 2007 at 7:26am
We will need at least a month to port it after we release Flowchart.NET 5.
rolend
Reply #4 - Jun 25th, 2007 at 11:05pm
would you please tell me what version about NetDiagram  now  related to FlowChart.net ?
rolend
Reply #5 - Jun 26th, 2007 at 4:54am
I try to execute the code on server side , but Applet on client side fail to display :
NetDiagram.LoadFromString( flowchart.saveToString());
ps: flowchart is v4.1 (.net1.1)
do i need to use .net 2.0 version then it will work?
Reply #6 - Jun 26th, 2007 at 5:57am
The diagram files saved/loaded by NetDiagram server side dll are compatible with Flowchart.NET. You might have problems if a diagram saved by Flowchart.NET contains Tag values from your custom type, that is not available in the Netdiagram-based application when loading the diagram there. If you need to use a custom type as a Tag in both a Windows Forms and a Web application, you will need to define it in a shared dll referenced by both applications.
wangqaa
Reply #7 - Dec 28th, 2007 at 4:46am
Hi:
you said
"We will need at least a month to port it after we release Flowchart.NET 5. "
IS it done?
Reply #8 - Dec 28th, 2007 at 9:08am
Not yet. We are going to release one more version using the old API.
lue
I love NetDiagram!
Reply #9 - Jan 9th, 2008 at 1:23pm
I would like migrate my projects from flowchart.net 5.02 to NetDiagram. Which version of NetDiagram we need to do this? When is this version available?
Regards Chris
Reply #10 - Jan 9th, 2008 at 1:35pm
You'd better wait for NetDiagram version 2, which should be available in March. Then both the Windows and Web forms versions of the control will use the common API from mindfusion.diagramming.dll, so you will be able to reuse much of your code.
wangqaa
Reply #11 - Jan 11th, 2008 at 9:40am
Hi:
  I try to migrate the past code.
In the past
We use webchart / flowchart.net approach of requiring you to use SaveToString, LoadFromString and html hidden fields.
I don't know how to show the flowchart  to client-side after work on server side when I use NetDiagram.
Can you give me an example flowchart work on sever-side and display on client-side.
My client side fail to display ...
Reply #12 - Jan 11th, 2008 at 10:43am
If you are using ImageMap mode, add ImageGen.aspx to your project. NetDiagram generates IMG elements that rely on that file to return the image as an image/jpeg MIME type data.
If you are using the JavaApplet mode, add the JDiagram.jar to your project. In that case your clients will need version 1.5 or higher of the Java runtime in order to load the client-side applet.
wangqaa
Reply #13 - Jan 14th, 2008 at 5:22am
Hi:
I used JavaApplet mode, and add the JDiagram.jar to my project.
First time- I try some simple work. Draw some box
in client and two sever controls button . one to count boxes the other to creat box. It works.
Then I want to test my old Flowchart(more complicated compute) migrate to NetDiagram.
In VS2005 debug mode, I can see the flowchart object's properties I set is correct in behind. But it can't display in client (IE).
I don't know what step I forgot.
I just think it will like the simple test I try
But it is not. ???
In the flowchart.net:
after deal with flowchart object you need to saveToString and Save in hidden text box and......
So it can dispaly in web....
NetDiagram:
after deal with flowchart object and..??
(I want to know ??)
(I read the programmer's Guide/Sever side reference/Serialization)
It seems the same...I still can't understand the different.
need your help~ ???
Reply #14 - Jan 14th, 2008 at 6:21am
How are you loading your old flowcharts? If you load a file from the Page_Load event handler, it should be automatically transferred to the client side.
This won't work if there are ControlHost nodes in your old flowcharts, because the client side applet cannot create Java objects corresponding to the Windows Forms controls hosted in the ControlHosts.
