Normal Topic Box Fromat change afterf firing evets (Read 2593 times)
rayan05
Mar 14th, 2008 at 2:32pm
Hi
I'm having a problem with 'NetDiagram'. When the web from reloads (after firing an event)  some boxes lose their formatting: the icon have black backcolor and boxes' . Size of the box also get changed.
Why?
Re: Box Fromat change afterf firing evets
Reply #1 - Mar 14th, 2008 at 2:38pm
Are you using the ImageMap mode, with .ico images loaded in the boxes?
rayan05
Reply #2 - Mar 14th, 2008 at 2:43pm
Yes.
I'm using Imagemap mode with .ico images
Reply #3 - Mar 14th, 2008 at 2:54pm
Ok, we know of this problem. It happens when the control tries to save the diagram in the view state. The .NET image encoder fails to save the icon image for some reason, and the control falls back the PNG encoder. However, the icon transparency is lost in the process. For now, load your icons from PNG images.
rayan05
Reply #4 - Mar 14th, 2008 at 2:59pm
Thanks lot.
It works
