Normal Topic typecasting the AxControl-Value in Delphi (Read 5168 times)
Mischa
Mar 13th, 2008 at 5:44pm
I want to implement a  flowchart-control in a box-item to show sub-graphs. My Problem is that the Value returned by the AXControl-property is not typecastable to tflowchart!
My Code:
box.Style :=bsAxControl;
box.AxControlId:='MindFusion.FlowChartPro.4.1';
newFC:= box.AxControl as tflowchart ;
or
newFC:= tflowchart (box.AxControl );
or
newFC:= tflowchart (idispatch(box.AxControl));
or
newFC:= tflowchart (IUnknown(box.AxControl));
using a Variant works, but I need a tflowchart -variable!
Help me Please!
Mischa
Re: typecasting the AxControl-Value in Delphi
Reply #1 - Mar 13th, 2008 at 8:04pm
I will have to install Delphi to try that. Does the Turbo Delphi for Win32 edition come with ActiveX support?
Mischa
Reply #2 - Mar 14th, 2008 at 9:55am
no it does not support third-party-components!!! ???
Reply #3 - Mar 14th, 2008 at 10:15am
It is a pity. Well then, I am installing their RAD Studio trial version.
Reply #4 - Mar 14th, 2008 at 12:40pm
This works fine:
procedure TForm1.Button1Click(Sender: TObject);
var b: box;
	fc: IFlowChart;
begin
	b := FlowChart1.CreateBox(10, 10, 100, 100);
	b.Style :=bsAxControl;
	b.AxControlId:='MindFusion.FlowChartPro.4.1';
	fc := b.AxRawPtr as IFlowChart;
	fc.CreateBox(10, 10, 30, 30);
end;
Typecasting does not work, because the flowchart's COM object is not an instance of the TFlowChart class. TFlowChart derives from the TOleControl and TWinControl classes, which in addition to wrapping a COM pointer, also provide various other members used to integrate a control into a VCL form.
From what I can grasp from the code generated by Delphi, it seems that TFlowChart just implements the IFlowChart API, and the members you would call through TFlowChart are exactly the same as the ones you get through IFlowChart.
Mischa
Reply #5 - Mar 14th, 2008 at 1:49pm
You are so fast!!! Only FlowchartX is faster then you Smiley
It helps a little bit:
IFlowchart does not contain a member named Width
IFlowchart does not contain a member named height
IFlowchart does not contain a member named free
IFlowchart does not contain a member named create
IFlowchart does not contain a member named ONboxclicked, On Arrowclicked and every else event
IFlowchart does not contain a member named Parent
IFlowchart does not contain a member named ParentWindow
IFlowchart does not contain a member named Align
is it possible to get the Tflowchart-Variable???
Reply #6 - Mar 14th, 2008 at 2:11pm
8) Width, Height, Parent, Align etc. have sense only when a TFlowChart is a child of a VCL form or control. Now that the flowchart is inside a box, you can control its size and location by means of the respective Box methods. I will check how you can attach events to the hosted flowchart.
Reply #7 - Mar 18th, 2008 at 3:52pm
From what I read in the Delphi help, importing using the "import type library" command should create a TOleServer-derived class that wraps the events and methods of any COM object. Then you could use the TOleServer.Connect method to connect the Delphi object to the COM object interface pointer (the hosted flowchart in our instance). However I cannot make Delphi generate a TOleServer wrapper for the IFlowchart interface - the result is always a TOleControl-derived class.
Do you know of any tool or option of the Delphi IDE that will let you import an ActiveX control as a TOleServer? Another option is to copy the TFlowChart code to another class, rename it to TFlowChartWrapper, and modify it so that it derives from TOleServer and not from TOleControl. Then the TFlowChartWrapper should let you connect to the hosted flowchart and handle its events.
