Normal Topic Resource View Drag and Drop error (Read 2557 times)
willywig
Mar 17th, 2008 at 8:18pm
calendar.GetResourceAt(client).Id()
Using the above on the ResourceView throws an error....
Referenced object 'GetResourceAt' has a value of 'Nothing'.
When in TimeableView this error is not thrown.
Re: Resource View Drag and Drop error
Reply #1 - Mar 18th, 2008 at 7:24am
There is a chance that the GerResource method would return null. For example, when the specified point does not lie over any resource or when you are not performing grouping by resource. If you are grouping by Contacts, Locations or Tasks, or not grouping at all, this method will always return null.
willywig
Reply #2 - Mar 18th, 2008 at 2:53pm
I am grouping by Contacts,  and using the GetContactAT worked... It is strange that the Getresource at works on the Timetable.
Reply #3 - Mar 18th, 2008 at 4:00pm
I think that was a bug that our developers have recently fixed. The correct method to use is GetContactAt, and in the next version GetResourceAt won't return contacts even in timetable view.
