Normal Topic How-to select Calendar item on right-click (Read 1971 times)
BudMan
Credidi me felem vidisse
Mar 18th, 2008 at 8:39pm
This should be easy for you guys. By default, a calendar item is selected when the user (left) clicks it. I would like to be able to do that when I right-click it. How do I do this? I have been playing around with the Calendar's GetItemAt() method but can't make any headway.
Re: How-to select Calendar item on right-click
Reply #1 - Mar 19th, 2008 at 7:47am
You can check the 'Clipboard' sample. The same thing is implemented there by handling the ItemClick event and adding the corresponding item to the item selection.
BudMan
Reply #2 - Mar 19th, 2008 at 1:48pm
Wonderful! Thanks.
