Normal Topic Behavior.Modify still allows creating new links? (Read 2369 times)
AnthonyBrien
Mar 18th, 2008 at 1:44pm
I have a couple of modes for users to edit my diagram. The diagram consists of custom nodes and link types.
* Selection: Nothing can be changed, I just want things to get selected.
* Link: Can drag to create links, but cannot move nodes.
* Nodes: Can click or drag to create new nodes.
I'm not sure how to accomplish this. When I set Behavior = Modify, I can still create links and nodes (of the default type, not my custom type) between my nodes. When I set Behavior = Custom, and CustomLinkType to my custom link class, I can still create nodes (of the default type) and similarly, when I set CustomNodeType, I can still create links (of the default type)!
If I set the CustomLinkType or CustomNodeType to null, I get exceptions when I try clicking or dragging on the diagram.
So what is the best way to only permit creating nodes, creating links or selecting objects?
Re: Behavior.Modify still allows creating new link
Reply #1 - Mar 18th, 2008 at 2:19pm
Modify should not let the users create links and nodes, but will still let them move existing items. You could use the following custom behavior class:
public enum EditMode
	Selection,
	Link,
	Nodes
public class MyBehavior : LinkNodesBehavior
	public MyBehavior(DiagramView view) : base(view)
		editMode = EditMode.Selection;
	public override InteractionState StartDraw(PointF point)
		switch (editMode)
			case EditMode.Selection:
				return new InteractionState(Diagram.Selection, 8, Action.Create);
			break;
		case EditMode.Link:
				DiagramNode node = Diagram.GetNodeAt(point);
				if (node != null)
					return base.StartDraw(point);
			break;
		case EditMode.Nodes:
				return new InteractionState(CreateNode(), 8, Action.Create);
			break;
		return null;
	protected override DiagramNode CreateNode()
		return new ContainerNode(Diagram);
	public EditMode EditMode
		get { return editMode; }
		set { editMode = value; }
	private EditMode editMode;
Reply #2 - Mar 18th, 2008 at 2:21pm
and then define aMyBehavior myBehavior; member in your form and use it like this
private void Form1_Load(object sender, System.EventArgs e)
     myBehavior = new MyBehavior(diagramView);
     diagramView.CustomBehavior = myBehavior;
     myBehavior.EditMode = EditMode.Nodes;
AnthonyBrien
Reply #3 - Mar 18th, 2008 at 9:55pm
Sorry, this was a silly mistake on my part, I was resetting the Behavior to LinkContainer in another place in my code. Thanks for the sample custom behavior class, it will make my code cleaner.
However I still have an issue, and this one is reproducible in the demo application with the Containers: When you set the Behavior to modify, and have two Containers side by side, selecting them by dragging a selection box around them makes one container child of the other one.
Reply #4 - Mar 19th, 2008 at 10:04am
This version fixes the selection problem:
https://mindfusion.eu/_temp/ctrsel_fix.zip
