Normal Topic Height of a table cell allowing content to fit (Read 1646 times)
TheEric
Mar 26th, 2008 at 2:23pm
I am using MindFusion.WebChart.FlowChart object to export charts on a web page.
I have some table which display a text in the first row.
I am wishing to compute the row's needed height in order to display all the text but cannot find a way to do it.
I am trying to use TextRenderer.MeasureText() but the resultat is far from accurate. I think this is due to the incorrect TextFormatFlags argument I am using.
I'd like to get the actual TextFormatFlags value used by the grid to draw the text but the closer thing I found is Cell.TextFormat.FormatFlags which is a StringFormFlags Undecided.
Does anyone have any idea about how to achieve this?
I am using Flowchart 4.3.
Thanks in advance,
Eric
Re: Height of a table cell allowing content to fit
Reply #1 - Mar 26th, 2008 at 2:49pm
Try the FlowChart.MeasureString method. For each cell in a row, pass the cell's Width as a value of the maxWidth argument, and set the row.Height to the max of the current height and the size returned by MeasureString.
TheEric
Reply #2 - Mar 26th, 2008 at 4:14pm
It does exactly what I needed Smiley
I noticed that when text is long, the returned height is a little bigger than needed but that will fit my needs (a little bigger is better than a little smaller).
Thanks again Stoyo!
