Normal Topic If anchorpoint is added to row,what does Y mean? (Read 1464 times)
consolejoker
Mar 31st, 2008 at 7:07pm
If you're creating a new anchorpoint, you have to specify Y. What does this mean for a row, if you're adding it to a row?
0 for Y means the top most part of the row, or is Y expressing top within bounds of the node itself? Its not behaving as I would expect.
Re: If anchorpoint is added to row,what does Y mea
Reply #1 - Apr 1st, 2008 at 8:04am
Y expresses percent of the row's height: 0 is the top of the row, 100 is the bottom, 50 is the middle.
consolejoker
Reply #2 - Apr 1st, 2008 at 1:00pm
Oh wow that is what is driving me nuts. I was thinking in pixels but that would obviously not scale well. So you went with %. Makes sense, thanks!
