Normal Topic Deleting nodes (Read 7574 times)
matt.s
Deleting nodes
Apr 3rd, 2008 at 12:41pm
I'm currently using the trial version of the WPF software and have come across some things that I'm struggling to get working;
- Deleting nodes
When I add a diagram to a ScrollViewer, and then add a node to the diagram, I find that I cannot select the node and delete it using the [DEL] key.
If I add a digram to a Grid and perform the same steps it works fine.
- Grid lines
I have grid lines turned on, but I have noticed that when you extend the width of the window that contains the diagram, the area containing the grid lines is actually thinner than the diagram itself, and is centered. The grid lines area is only increased in size when you add a node and move it outside of the grid lines boundary.
- Dashed links
When I link two nodes using a pen with a DashStyle, when I serialize the content using SaveToXml and LoadFromXml the dash style is lost and the link appears with a solid line.
I hope you can help me with these things.
Thanks in advance
Matt
Re: Deleting nodes
Reply #1 - Apr 3rd, 2008 at 2:06pm
Set <ScrollViewer Focusable="False" ...>
matt.s
Re: Deleting nodes
Reply #2 - Apr 3rd, 2008 at 2:10pm
Hi Stoyan,
Thanks for the quick reply.
This fixes the delete node/link problem - have you any ideas on the other problems I'm having?
Matt
Re: Deleting nodes
Reply #3 - Apr 3rd, 2008 at 2:13pm
Hi Matt,
Grid lines are drawn only inside the Diagram.Bounds rectangle. Set a larger initial value for Bounds and the lines will cover a larger area.
Re: Deleting nodes
Reply #4 - Apr 3rd, 2008 at 2:19pm
and regarding the pen serialization, we'll fix it in the 1.0.1 release.
matt.s
Re: Deleting nodes
Reply #5 - Apr 3rd, 2008 at 2:20pm
Thanks Stoyan - great support service!
matt.s
Re: Deleting nodes
Reply #6 - Apr 17th, 2008 at 3:22pm
Hi Stoyan,
Out of interest, do you have any indication when this release will be?
Matt
Re: Deleting nodes
Reply #7 - Apr 18th, 2008 at 5:32am
Hi Matt,
The next release will be in May. We can send you a fix for the pen sooner if thats urgent.
