Normal Topic Change DiagramNode snap location (Read 5054 times)
Todd
Apr 16th, 2008 at 3:01pm
Is it possible to change the snap location of a node on the diagram grid? It seems that all of the shapes I create are confined to snapping to the top left.
Primarily I am interested in having the center of the shape be the point that snaps to the grid.
Re: Change DiagramNode snap location
Reply #1 - Apr 16th, 2008 at 3:11pm
That's not supported out of the box. You could align nodes in response to NodeCreated and NodeModified handlers, with the help of the AlignPointToGrid method. Once a node is created or moved to a new location, find the grid point nearest to the node center, and offset the node so that its center coincides with the grid point.
Reply #2 - Apr 16th, 2008 at 3:21pm
Note that AlignPointToGrid will return the location of a grid point only when the AlignToGrid property is enabled. So your event handler should look like
diagram.AlignToGrid = true;
Point center = ...; // find it from node.Bounds
Point alignedCenter = diagram.AlignToGrid(center);
float dx = alignedCenter.X - center.X;
float dy = alignedCenter.Y - center.Y;
diagram.AlignToGrid = false;
and finally offset node.Bounds with (dx,dy).
Todd
Reply #3 - Apr 16th, 2008 at 4:22pm
Thanks, I think I might be able to make that work.
Though, just in case anyone else ever needs this in order to calculate allignedCenter in Stoyo's code call AlignPointToGrid not AlignToGrid.
The code I'm using currently looks like:
Point ptCenter = node.GetCenter();
Point ptAlignedCenter = diagram.AlignPointToGrid(ptCenter);
double fDeltaX = ptAlignedCenter.X - ptCenter.X;
double fDeltaY = ptAlignedCenter.Y - ptCenter.Y;
Rect rectBounds = node.Bounds;
rectBounds.Offset(fDeltaX, fDeltaY);
node.Bounds = rectBounds;
