Normal Topic Problem with selected nodes after loading xml file (Read 1476 times)
oakenshield
Apr 4th, 2008 at 9:22am
I'm encountering the following blocking problem : when I save a diagram with one node selected in a XML file, and when after I re-load this file in the applet, the selected node can't neither be selected, nor be moved !
I have seen that the attribute 'selected' of the node is 'true' (despite the fact that it's not displayed selected), but this attribute can't be changed...
Can you tell me if this problem is a known bug ?
Thanks in advance !
Re: Problem with selected nodes after loading xml
Reply #1 - Apr 4th, 2008 at 10:03am
Yes, this should be fixed now. Look for new dlls in the private messages area.
