Normal Topic Grid lines and arrow (Read 2330 times)
koosala
Java Happens
Apr 5th, 2008 at 5:08pm
When if the grid is enabled, and a box is dragged, the box is aligned to the grid. Is it possible to make the arrows too align to the grid when they are being created?
Praveen
Re: Grid lines and arrow
Reply #1 - Apr 9th, 2008 at 8:25am
This can be done only if the node outlines pass through grid points, i.e. if the node has a rectangular shape and it is aligned to the grid. How would you suggest to align the arrow end when the node is not aligned, or it has an oval shape?
koosala
Java Happens
Reply #2 - Apr 9th, 2008 at 8:40am
Is it possible for rectangular shapes aligned to the grid?
Praveen
Reply #3 - Apr 9th, 2008 at 10:37am
Yes, but it's still tricky. The control treats all node shapes as closed sequences of lines and beziers, and does not keep any intrinsic information whether a shape is a rectangle. So we'll have to use a lot of geometric calculations to find grid points that lie on the node borders, or otherwise define a Rectangle shape element (as there is already a RoundRect) and implement that just for shapes whose outlines are defined as a Rectangle.
