Normal Topic Image ratio on chart (Read 1226 times)
pelion
May 6th, 2008 at 3:54am
What is the ratio of image width to chart size?
In other words, if I have a 32 x 32 image, what is the optimal size on the chart?
Re: Image ratio on chart
Reply #1 - May 6th, 2008 at 8:11am
Flowchart.NET honors the DPI attribute of images. If you load a 96x96 image whose DPI value is 96, Flowchart.NET should display it so that the image occupies exactly one inch on the screen, even if that's not 96x96 screen pixels.
The image size should correspond to the pixels it occupies on the screen only if the image's DPI is the same as the screen resolution. If you want to ensure that for an image, call the Bitmap.SetResolution method to set the image's resolution to that of the user's display.
