Normal Topic Arrow Deleted Event (Read 1575 times)
pelion
Arrow Deleted Event
May 7th, 2008 at 9:17am
Hi Stoyo,
I am having some issues on a chart that I have tracked to the ArrowDeleted event being fired when the Chart.ClearAll is called, as well as when a user deletes an arrow.
Is there anyway to limit when this event fires, or once it has fired, what the Action that caused it was?
Thanks in advance
JC
Re: Arrow Deleted Event
Reply #1 - May 7th, 2008 at 10:36am
Hi JC,
Indeed, raising Deleted events in response to method calls is very inconsistent with how the rest of the events work. We'll probably fix this in a future release. Until then you will have to keep track of the event context yourself, for example:
boolean cleanup = false;
void someMethod()
	cleanup = true;
	diagram.ClearAll();
	cleanup = false;
void diagram_LinkDeleted(...)
	if (!cleanup)
pelion
Reply #2 - May 7th, 2008 at 10:25pm
That's pretty much how I've handled it, just wondered if there was anything inbuilt.
Thanks again
JC
