Normal Topic CustomDraw box (Read 2151 times)
tronied
CustomDraw box
May 7th, 2008 at 10:38am
Hi. I have just started out trying to use JDiagram, and am wanting to do some custom drawing on a box. I looked at the API, and I am afriad I didn't find it too helpful. I then looked in one of your samples and took the following:
        //After I create the flow chart object
        newFlowChart.addFlowChartListener
                new FlowChartAdapter()
                        public void drawItem(ItemDrawEvent e)
                                onDrawItem(e);
       //New box setCustomDraw property
        box.setCustomDraw(CustomDraw.Full);
    public void onDrawItem(ItemDrawEvent e) {
        if (e.getItem() instanceof Box) {
            Graphics2D g = e.getGraphics();
            g.setColor(Color.BLACK);
           //Do something crazy just to see if its working...
            g.fillRect(0,0,1000,1000);
Unfortunately this doesn't seem to work, and I can't figure out why. I stepped through the code, and gets to the line which adds a flow chart listener, but the itemDraw() never gets called. The flow chart other than that is displaying fine though...
Any ideas? *
* Sorry if this is a frequently asked question, but I couldn't see any examples on the web.
Re: CustomDraw box
Reply #1 - May 7th, 2008 at 11:30am
This worked for me:
Box b = flowChart.createBox(10, 10, 40, 40);
b.setCustomDraw(CustomDraw.Full);
flowChart.addFlowChartListener(new FlowChartAdapter()
If you created your box instance by just calling the constructor, have you also used the add() method to add it to the flowchart?
