Hot Topic (More than 10 Replies) Custom Behaviour (Read 10243 times)
Kortexito
Custom Behaviour
May 8th, 2008 at 2:35pm
Hi Stoyan,
My diagram contains my custom controls wrapped by DiagramNodeAdapters. Lets assume my control is a canvas with a button inside. I am trying to develop a custom behaviour that would allow me to accomplish:
- if a user clicks on a button: nothing happen, button gets clicked and corresponding handler in my control code gets executed
- if a user clicks mouse down on a canvas (not on a button): a Move cursor appears and the user is able to move the corresponding DiagramNodeAdapters until he releases the mouse button
- if a user clicks mouse down on (or let's say 3 pixels around) any of anchor points: a new link is created and starts follow the mouse cursor.
Could you please hep me with this behaviour?
Best Regards.
Re: Custom Behaviour
Reply #1 - May 9th, 2008 at 9:22am
Try this -
class CanvasEx : Canvas
	public CanvasEx()
		button = new Button();
		button.Content = "hello";
		Children.Add(button);
	public Button button;
class BehaviorEx : CustomTypesBehavior
	public BehaviorEx(Diagram diagram)
		: base(diagram)
	public override InteractionState StartDraw(Point point)
		HitTestResult htr;
		DiagramNode node = Diagram.GetNodeAt(point, true, false);
		if (node != null)
			if (node.AnchorPattern != null)
				foreach (AnchorPoint p in node.AnchorPattern.Points)
					Rect r = node.Bounds;
					Point appos = new Point(r.X + r.Width * p.X / 100, r.Y + r.Height * p.Y / 100);
					if (p.AllowOutgoing && Math.Abs(point.X - appos.X) <= 3 && Math.Abs(point.Y - appos.Y) <= 3)
						return base.StartDraw(point);
				DiagramNodeAdapter adapter = node as DiagramNodeAdapter;
				if (adapter != null)
					CanvasEx canvas = adapter.UIElement as CanvasEx;
					if (canvas != null)
						GeneralTransform tr = Diagram.DocumentPlane.TransformToVisual(canvas.button);
						Point localPoint = tr.Transform(point);
						htr = VisualTreeHelper.HitTest(canvas.button, localPoint);
						if (htr != null && htr.VisualHit != null)
							return null;
						else
							return new InteractionState(node, 8, MindFusion.Diagramming.Wpf.Action.Modify);
Add the following to the form’s constructor
diagram.Behavior = Behavior.Custom;
diagram.CustomNodeType = typeof(CanvasEx);
diagram.CustomBehavior = new BehaviorEx(siteMap);
and
e.Node.AnchorPattern = AnchorPattern.Decision1In3Out;
to the NodeCreated event handler.
dn
Reply #2 - May 16th, 2008 at 10:03pm
Hi
I'm trying to implement custom behaviour, basically only want to be able to move nodes but disable other default editing behaviours like resize and dragging to add links.
I have a LinkCreating event handler to cancel link creation, but it still allows the user to drag to start drawing a link so it seems I need to intercept the mouse move / drag event earlier, what's the best way to do that?
I started by adapting the BehaviorEx class suggested above, but it's still allowing the drag to initiate drawing of the link, which I want to prevent.
thanks
D.
Reply #3 - May 19th, 2008 at 8:14am
Use Behavior.Modify, set EnabledHandles = Move for all nodes, and either disable AllowOutgoingLinks for all nodes, or call e.CancelDrag() from the LinkCreating handler.
dn
Reply #4 - May 20th, 2008 at 4:37pm
thanks, that works to prevent start of link creation
but now after that change, sometimes dragging a node to move it doesn't "stick", it intermittently reverts back to the starting drag point.
sometimes the move cursor changes to a "not allowed" cursor if I pause long enough once the move/drag is started.
D.
Reply #5 - May 21st, 2008 at 9:16am
Are you handling the NodeModifying event? This might also happen if you drag the node outside the current Diagram.Bounds rectangle and AutoResize is disabled.
dn
Reply #6 - May 21st, 2008 at 5:35pm
no, wasn't handling the NodeModiying event.
now I tried using DiagramNodeAdapter with my own UIElement to get the fancy look our UI designer wanted, and now drag/move seems to work ok
but now the new problem with DiagramNodeAdapter is that it draws a thin white dotted rectangular border around my WPF Ellipse when I select it, how do I get rid of that?
thanks
dn
Reply #7 - May 21st, 2008 at 6:02pm
to answer my own question...
also need to add HandlesStyle = HandlesStyle.Invisible to eliminate the thin white dotted rectangle when DiagramNodeAdapter/UIElement selected.
Paul Eden
Reply #8 - Jun 6th, 2008 at 11:33am
Hi
I just upgraded to the 101 build you posted on the 5th June - are there any changes that would prevent this custom behaviour code from working?  I put the class into a standalone DLL, importing the WFP and WPF.Behaviours namespaces, but the BehaviourEx.StartDraw method fails to compile stating that there is no suitable method found to override.
Any ideas as to what I did wrong?
Many thanks
Paul
Reply #9 - Jun 6th, 2008 at 12:06pm
The method signature should look like this:
Is it the same in your class?
Paul Eden
Reply #10 - Jun 6th, 2008 at 12:23pm
Yes, I copied your original class code from early on in this thread.
Reply #11 - Jun 6th, 2008 at 2:01pm
Could you copy all the compiler output here?
